blt2ski
Aug 12, 2013Moderator
powderman426 wrote:
I can't understand why you would want passenger tires on a trailer. Just get a set of Maxxis tires along with a TPMS and enjoy life.
The issue is the size one might need. If you get 165, 175, or 185 13 tires, they only come in a P series, altho you can get C rated tires at 45 lbs. They are NOT ST rated for trailers, but are common trailer tires for smaller trailers. I saw a SMALL boat trailer with 4.80x12 tires in an B load rating. These granted are made for trailers, but still only hold 30-32 lbs of air. I would not be surprised if the trailer axel had more than 300-400 lbs on it! One does not need high capacity tires for this load.
It will come down to a how you use the trailer, how much load etc. I would have no issue throwing an appropriate p metric to get me to a tire shop. Really no different than using some of the really small spare tires that come with some rigs. Emergency use only!
Marty
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
