My HTT came with load class C 13" tires, barely adequate for the job. I can replace them with class D, either in a radial rated for 16xx pounds or bias rated at 17xx pounds. The cost is the same. W...
My Forest River came with Load Range C even tho it had a dry weight of just around 6700 lbs. I went to the Load Range E for the extra safety margin and the forged aluminum wheels hold the 80 psi, no problem. No regrets been using Maxxis tires for the past 14 years or so.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
