Woodtroll
May 11, 2017Explorer
I have one temperature gauge on my truck on a three-way switch that I use to monitor engine oil, transmission, and differential temps. It works just fine - whenever I want to check on the temps I just slide the switch through the three positions. However, my gauges are aftermarket (Autometer), and are electrical gauges (not mechanical) that use a sensor that varies the resistance on the ground wire that goes to the gauge. If your transmission temp gauge is a factory gauge, knowing what vehicle you have would help folks make appropriate suggestions.
Good luck!
Regan
Good luck!
Regan
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 11, 2025
