pianotuna
Aug 28, 2016Nomad III
Hi,
The heat source does not matter. Permanent irreversible damage can happen in 15 minutes.
ford-willy wrote:
Please correct me if I'm wrong here. I thought the out of level refrig damage issue only applied when on propane. The flame when burning "off center" can do damage to the unit. So if that is correct, and if you have generator capabilities, just run the refrig on 120v while stopped and significantly off level. The electric coil heater does not need level. Is that correct? ------ Of course many people dont have generator capabilities.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
