- K_CharlesExplorerOurs is always on unless winter. Most parking lots and rest stops are level enough for the fridge. If I can't walk comfortably in the parking lot I won't park there.
- nineoaks2004ExplorerI usually leave mine on and most of the time even at home I have never had any trouble with any I have owned. However as stated the new ones are designed to keep the items cold for 8 hours (as stated by the manufacturer)
- KD4UPLExplorerI never shut mine down from the first trip in the spring until the last trip in the fall. The original fridge is 13 years old still works fine.
I do try to park on level ground. - pianotunaNomad IIIHi,
Before I had the ARP protection device I shut down my fridge or drove in circles in the parking lot until I found a level spot.
Now I still try for level--but I'm far less concerned.
And yes, damage can happen in 15 minutes.
Replacement cost for my fridge is $3000.00 - AJRExplorerMine is on from the day I start my first trip till I winterize the camper.
- SoundGuyExplorerHere in Canada one of these 6 cu ft gas absorption fridges can run $2500 to replace so with that in mind I always shut the fridge off whenever we intend to stop more than a few minutes. Some may consider it unnecessary but I figure better safe than sorry and having owned a number of these fridges it's a process that's worked well for me as we've thankfully never suffered any sort of fridge failure.
- 3oaksExplorerWe leave ours ON when stopping for pit stops and lunch breaks along the way even if out of level. Going on 10 years without a problem.
- 2oldmanExplorer II
sfpcservice wrote:
x2
.. if it is beyond that I will shut it down as soon as we stop. - catkinsExplorer IIUnless really out of level, we leave it go. Normal walking OK - we let it go. When in doubt - shut it down and leave closed. Fridge will stay cold for at least 8 hours without running if all was cold before you shut down.
- Diesel_CamperExplorerOur refrigerator is supposedly able to operate safely as long as you can comfortably stand or walk in the rig. Mostly it stays on, but if it is beyond that I will shut it down as soon as we stop. I'veread that it only takes about 15 minutes before damage to the refrigerant can take place.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
