IDman wrote:
Yes, we always ran with LP on UNTIL we stopped for fuel. I would pull over before we got to the station and turn it off at the cylinder. After fueling, I would pull out of the station, or at least away from the fuel pumps, and turn it back on. Then I would enter the TT to make sure the frig was lit again.
Safety first!!
Wait a minute... If all you do is turn off the valve at the cylinder, isn't the fridge still on and the igniter is now trying to light and 'sparking' until it shuts itself off? Now, leaving your fridge in a "check" state and even if you turn the cylinder valve back on, the fridge is not going to just lite itself again, is it??
Maybe I missed something in your statement?
If I were to turn mine off (which I don't do) unless the trailer is going to sit out of level for a period of time while on the road, I turn it off on the panel, but leave the valves alone.
Only time I've ever had to turn the fridge and the valves off was on a ferry..
Anyway, to the OP.. There are literally "thousands" of posts on this topic and you are either in the 'camp' of "I leave it on", or "I never run with it on"... There are the ones that shut down while fueling, and that's fine..
In the end, it's just your own "risk/reward" kind of thing.. :)
Do whatever makes you feel comfortable as you go down the road, as there are a million other things to worry about when in transit!!
Good luck! Mitch
