- wny_pat1Explorer
SuzzeeeQ2012 wrote:
DiploStrat wrote:
that sounds WONDERFUL as I"m reading the material on the website. Showers every single day and warmth. How much does it cost?
I have a Webasto Dual Top Evo on my Tiger. Does hot air heat and hot water. Next to no noise. Runs on diesel from the truck's fuel tank or, if you have a gasoline engine, a small, separate diesel tank.
Watch the little video.
//cringes and hides eyes// lol
if over $1,000 might be out of our reach :( How much diesel does it use?
Not new or installed at that price. But do you homework and take a look at ebay. The little bunk heaters can drive one right out of the bunk in a tractor trailer. - SuzzeeeQ2012Explorer
if over $1,000 might be out of our reach :( How much diesel does it use? - SuzzeeeQ2012Explorer
beemerphile1 wrote:
SuzzeeeQ2012 wrote:
wny_pat wrote:
See if you CPAP is both 110 AC and 12 VDC....
it's only 110...
You might be surprised, look at the label on the machine. Currently Resmed units are 24v and Respironics are 12v. Either can run directly from 12v with the appropriate adapter.
The Resmed adapter is about $75 and the Respironics adapter is about $25.
we hooked it up at one time from the power cord to the 12v plug hubby installed by my bed. I didn't work all night for some reason. Not sure what plug we used, I can't remember it's been a few years :o I guess when I said I was only 110 I wasn't remembering that :o - wny_pat1Explorer
SuzzeeeQ2012 wrote:
No. It is diesel fired, much like the Aqua Hot units, but much smaller. Your engine does not have to run. They even make models to preheat the little VW tdi engines.DiploStrat wrote:
we're in a diesel pusher. So...with these, sounds like there would have to be an engine running all night..not sure I want that since the engine is under our bed - SuzzeeeQ2012Explorerefficiency? I just wanna be warm at 5 AM lol
really curious about the cost of the EVO heater mentioned above.
sounds GREAT but I bet it's prrrrrrrrcccey!! - beemerphile1ExplorerThanks for the info wny_pat, but you need input and output BTU to calculate efficiency.
- wny_pat1Explorer
beemerphile1 wrote:
My point has always been that the PlatCat doesn't give any specs so we have no idea. Your opinion is valuable but is only conjecture. Your regulated furnace gives output and input BTU making it a piece of cake to know how efficient it is.
My point has also always been that if you are going to vent the exhaust - why waste the extra money on a platinum catalyst?
Model...................3P12............6P12
Fuel....................propane.........propane
BTU Input (max).........3000 BTU........5,200 BTU
Power...................12 Vdc..........12 Vdc
Fuel Consumption........1/8 lb /hr (34 hr per gallon) 1/4 lb /hr (17 hr per gallon)
Operating Cost......... .04 /hr.........08/hr
Current Draw...start.....5 amp (for 2 minutes) 5 amp (for 2 minutes)
.........................run, exhaust blower less than 0.5 amps less than 0.5 amps
Gas Pressure.............11" W.C. 11" W.C.
Size .................. height 14" 21"
........................width 12" 12"
........................depth 5 3/8" 5 3/8"
Gas Connector...........3/8" flare 3/8" flare
Mounting surface or 2 3/4" recessed surface or 2 3/4" recessed
Exhaust Vent Tube Size..1 1/2" O.D. 1 1/2" O.D.
Area Heated Up to 100 sq. feet* ....Up to 175 sq. feet*
Finish** powdercoat powdercoat
Ignition (no flash, no flame) Automatic Automatic
Automatic Temperature Control Includes wall thermostat Includes wall thermostat
* Depends on climate, insulation, room heat loss.
Safety System:........................Power exhaust venting removes 100% of combustion by-products. Automatic Safety Shut-off in case of malfunction. No open windows are required. Operates safely at altitudes above 5000 ft. - beemerphile1Explorer
SuzzeeeQ2012 wrote:
it's only 110...
The Resmed adapter is about $75 and the Respironics adapter is about $25. - SuzzeeeQ2012Explorer
we're in a place with iffy internet, cant'get the video to work. That's the problem while boondocking...internet. Another problem to solve along the way lol So, takes no electrical hookup, you hook it to your water and fuel line from what I can gather on the website. So, is the machine something you take off when you're on the move? Is it permanently attached to the side of your motorhome? - SuzzeeeQ2012Explorer.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 27, 2025
