Cecilt's avatar
Cecilt
Truck Tire Pressure
I have been running 80 psi cold in my front and rear truck tires. Truck is '09 F-250, crew, 4x4, with factory 20" wheels. Tow a 9500lb loaded TT. Not sure why but just thought it was safer to max the pressure when pulling this much weight.
Looked at the door jamb and it says to use 65 psi front and rear. No reference is made to if truck is loaded/towing a camper. I think this sounds low. I did air down to 75 rear and 70 front and it felt much smoother going down the road. If you are towing a decent amount of weight do you "trust" the sticker or rely on the sticker when you are just driving without towing? tks
  • I run the door recommended pressure of 65 when empty and 75 when loaded. Max is 80. Been towing my fiver for almost 5 years and had zero issues. knock on wood..
  • Also have an '09 F250 and inflate the tires to 80 psi when towing. Have tried somewhat lower but handles better at 80. When towing you've got the additional tongue weight plus passengers, kids, pets and camping gear and other stuff in the bed.
    For lots of good info. from a tire engineer, go to RVtiresafety.com and/or google "tireman9 tow vehicle tire pressure".
  • Go by the door sticker unless you are feeling very scientific about it and get the axles weighed independently. In the latter case, you can look up the recommended pressures for the size and type of tire and base your pressures on that; usually it's not a bad idea to round up a bit in case you should happen to be a little more heavily loaded at some point. The door jamb pressures are generally determined based on the maximum permissible axle loads for the vehicle, probably with a bit of a safety cushion.
    Running with overly high pressures will lead to a harsher ride. It may also lead to somewhat uneven tire wear (middle before the outside edges), and more importantly degraded vehicle handling. Overly inflated tires have worse traction in extreme conditions like emergency maneuvers than properly inflated tires. (On some vehicles, too, overinflated front tires can lead to interesting steering handling.)
    The pressure molded in the sidewall of the tire is the maximum permissible in the tire, and corresponds to the maximum load the tire is rated to carry. It's entirely possible that your rims may have a lower maximum pressure rating than the tires that are on them.
    Edit: The door sticker tire pressures of course only apply to the factory tire size and type, as also specified on the sticker. If you're using tires of a different size or type, particularly ones that are significantly different, you should go by the weights and the tire maker's tables. (Weights in this case could be actually measured weights or the GAWRs from the sticker.)
  • I use what the door says. That is what the factory calls for your particular truck at the max load it is rated for. A lot smoother ride too.
  • I go by the sticker. Tires should be aired to the weight they are supporting. Max pressure is not necessarily the correct pressure.
    And if I will not be towing in the near future I will "air down" the rear tires.
  • I go by the PSI shown on the sidewall of the tire. I always keep pressure at the max shown even if no load in the truck.
    No reason, I just do it so I don't have to worry about adding air if carrying a load. Some folks lower the pressure to improve the ride.
Looking for advice before your next adventure? Look no further.25,165 PostsLatest Activity: Sep 20, 2025
