Need-A-Vacation
Apr 14, 2015Explorer
Talk to your tire dealer and see if they have a set of 15" wheel/ tire combo mounted already that you could have mounted to check for clearance. Or if they will work with you. They may be able to determine if 15" tires will work by looking at your trailer with the 14" tires on it.
Regardless what tire you go with, if you step up to a LR D make sure the rim is rated for the tire pressure.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
