GaryS1953
Aug 01, 2018Nomad
Ok, just found this on the Jayco Owners Forum:
"Don't caulk your shower surround.
It's been discussed around the forum a couple times, but I just wanted to share my experience with the hope of keeping another owner from making the same mistake I did.
When we purchased our trailer last year, I took one look at the shower surround and the huge gap at the bottom between it and the shower pan and thought "now, that's just sloppy, why is that not sealed?"
So in my final delivery requests, I asked the tech to go ahead and run a bead of silicone around there and get it all sealed up nice. I asked him to validate my request, and he responded with "that's what I'd do if it were mine". Well, later I was reading this forum, and I learned that was a bad idea. You see the space between the shower liner and the wall is subject to moisture issues, and the gap at the bottom of the shower surround is designed to allow air to flow through so it can dry up nice.
So I put removing that silicone on my list of things to fix a couple months ago and thought "well, I'll get to it sooner or later". Well, last weekend when we were out, I noticed a spot where the caulk had come loose a little bit, and there was a reddish stain there. You know, like the kind of stain that happens when that Luann wall board gets wet? I grabbed my pocket knife and began pulling some of the silicone away, and brownish red water started coming out. So I had a somewhat major freak out and envisioned myself pulling the shower liner away and finding all kinds of horrific things like mold and rot.
Well luckily when I got home and got everything apart enough to take a look, it turned out that some wood shavings had dropped down into that part of the shower pan, and water did in fact get back there, but it was just that little bit of construction debris that had gotten wet, and the brownish red stained droplets leaked out into the shower pan.
I really lucked out on that one, and I pulled all the caulk from around the threshold between the shower pan and the liner. Now I'm left with the job of removing all the silicone residue. I'm glad I got to it sooner rather than later, because that could have been a huge problem.
Don't make my mistake, that shower liner is designed to overlap the lip of the shower pan so any moisture runs into the shower, and the air gap is designed so anything left back there can dry out."
Based on this I'm still not sure. I have a bathtub, not a shower per se, and there IS no shower pan, unless the tub is considered the shower pan.
__________________
__________________
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
