RavensFan24's avatar
RavensFan24
TV Reception Issues
I have 3 TVs in my RV. The main tv that came with the RV and the one I installed in the bedroom get the same TV reception via the roof antenna. All 3 TVs are plugged into the cable outlet and the booster is turned on. The outside TV also came with the RV and is hooked up the same way as the other two TVs, but it gets much fewer channels than the other two TVs. I don't understand why.
Any tips on getting the outside TV to have better reception? I tried switching out the cable on the TV, as it was cut too short and gets maxed out when extended sometimes. That didn't help.
Any ideas are appreciated. I want to watch football by the campfire tonight and I get NBC beautifully inside, but not at all outside.
  • If you have done a channel scan recently then maybe start checking all connections on plug plates (both sides) and any "Y" that may be in that run.
  • You could extend the cable on the outside TV to connect to your antenna and booster amp, inside, or install a secondary antenna and connect the outside screen to that.
    FWIW, I built my own antenna in an afternoon. If you buy one, look at the specifications and make sure it is built for the frequencies of your favorite channels.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 25, 2026
