Jack1776's avatar
Jack1776
type of hitch
I have another question, but not solar. I just purchased (on order) a new gulfstream vintage cruiser 19ft ERD, single axel. Weights about 3000lb. I have been told that I shouldn't use a weight disbursement hitch (it could bend the frame) but I should use a sway type hitch. But I was also told that the wt disbursement hitch is ok as long as you stay within the weight limits of the trailer...Confused
  • Who told you the frame would bend?
    Have never heard that one before. I imagine that some King Kong fool could do it,but not when the hitch is installed set up and used properly
    I am a big believer in the use of WDH.Even if not necessarily called for to restore front axle weight, they add a certain level of sway control, stability and rigidity to your unit, all good things
    first, it's called a Weight Distribution Hitch. 2nd, what are you towing with? 3rd, DON'T use fictional dry weights. that trailer will have a GVWR of nearly 5000lbs. So need to know what you're towing with.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
