XR4rider's avatar
XR4rider
Upgrade to 16" wheels ,seek opinions for tires (LT vs ST?)
I know this topic has been beaten into the ground, however, as I read forum after forum about the LT vs ST topic, I noticed a lot of people posting about changing to LT tires have heavier trailers with heavier axles (6,000, 7000lbs etc).
I just purchased a new light 29' 5th wheel. The dry weight is about 7300lbs and it came with 4400lb LCI axles. The trailer came with cheap ST225/75-15 load range D tires. The first upgrade I would like to do is take of the current 15" wheels and put on 16" wheels. After reading all the different opinions about LT vs ST tires and reading about what brand tires people are using, I think I have narrowed it down to either:
1) Michelin XPS Ribs LT225/75R16 weight = 50lbs
2) Bridgestone Duravis LT225/75R16 weight = 52lbs
3) Firestone Transforce HT LT225/75/16 weight - 34lbs
All those listed are load range E.
I have thought about sticking with the 15" but seems there are more, and better, tire options with 16"s.
So my question is will running the Michelin or Bridgestone tires cause more long term wear on other components because of their heavier weight? The Firestone Transforce is quite a bit lighter.
I have read through various forms that people have had good experiences with all three brands.
I will be traveling around the country for the next 2 years so I will be putting quite a bit of miles on the trailer, so trying eliminate as many blowouts and mechanical issues as possible.
Thanks for the thoughts and opinions
  • donn0128 wrote:
    Your first problem is trying to find 5 lug 16 inch wheels. From there LT tires would be your best choice.
    Tire Rack has them.
  • Sorry, I forgot to mention, yes it is 6 lug. The current wheel is a 15x6" wheel. Ive found a few 16x6" or 16x6.5" wheels that will work. I guess I was a bit concerned with the extra tire weight of the Michelin. Bit I have read a lot of good reviews of them.
    I believe your first comment is stated backwards because on the heavier RVs, its harder to find an LT tire that has the same weight rating as the ST tires do. For example is the Sailun G rated ST tires that have a 4400 or 4800 lb weight rating, not sure they have a designated LT tire comparable. Goodyear Endurance ST tires may be the same also. Actual weight of the tire is really irrelevant on an RV.
    As others have mentioned, in order to change up to 16" wheels you will have to have 6 lug wheels on your RV.
    He probably has 6 lug wheels.
    I would check the recommended wheel width for the Michelins, then get the wheels and tires and travel with confidence.
  • Get the Bridgestone Duravis that fit your needs if you can fit wheels to your rig. They are awesome tires. Heavier weighing tires have no effect other than more rubber on the road and more protection from the elements.
  • Your first problem is trying to find 5 lug 16 inch wheels. From there LT tires would be your best choice.
