jnolan72's avatar
jnolan72
upgrading the Hitch from class 2 to 3 on my motorhome
I have a 2004 coachmen freelander 2490 SO
The chassis a E450 with a GCWR of 20,000 and current weight of around 14,000
I currently have a class 2 hitch and need to upgrade to a class 3 to tow my 3500lb car.
The motorhome I have has a small frame extender and is 24Feet long
Can I upgrad the Hitch?
  • This is a "Hidden Hitch" (brand) that is rated at 5000 pounds or 6,000 while using a weight distribution system. It will work with any frame width from 30 - 46", so might also work on trailer frames as well as your motorhome.
    RV hitch - 31" to 46" frame width
    They have other models, you can search for them. This is the one I was considering for my 2002 E-450 chassis. But I may still have a custom hitch built. Like you, I have a very short chassis extension, my overall length is only 23'.
    I can attach to the Ford frame, and do anything I want if I attach there. Then run a 12" long 2" receiver holder back to the bumper (so it will not stick out or be way under the bumper). My plan includes 3/16" thick flat stock to hold a 3" OD cross member, and 2.5" OD (2" ID) bar going back to the bumper. I know a certified welder, and he can built it for me. I have a 22,000 GCVWR, and the V10 engine with 4.63:1 rear axle ratio. My GVW is only around 8,000 pounds or 9,000 ready to go camping, so I am also a lot lighter. My plan includes a 10,000 pound trailer and 1,200 pounds of hitch weight. The E-450 that I have has a rear mounted wheelchair lift, and 12 seats.
    Good luck on your project.
    Fred.
  • You really should ask the manufacturer of the RV. Odds are they will say "no."
    My guess is they put the Class 2 hitch on it because that is all they are willing to guarantee the frame extension for.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
