Paulx's avatar
Paulx
Use WD hitch or not?
I have an 18' TT with dry weight of 3700 lbs and tongue weight of 500 lbs, and a 2014 Dodge Ram 1500 to tow it with (120" wheelbase). I did get an e2 WD hitch with the trailer but wonder if I really need it. Also it is a heavy, greasy beast and annoying to hitch up. The stinger is long, thus increasing the lever arm and making sway happen more readily.
So I bought a simple aluminum stinger and ball and hooked up with that, and also put my 250cc motorcycle in the bed of the truck (weight about 270 lbs), which is how I intend to run it.
The truck unloaded has the back end higher than the front (using the wheel well arch tops to measure), presumably because pickups are designed to carry a load in the bed. With the weight carrying (WC) hitch on and the TT hooked up and the motorcycle in the bed, the truck is exactly level (and the TT is almost level, just a tad lower up front). In hooking it up, the truck front wheel wells have come up just a quarter of an inch. I figure the load reduction on the front is around 225 lbs, with nobody seated in the truck.
BTW I have removed the 65 lb tailgate as it gets in the way, which of course removes maybe 100 lb from the rear axle. I could also remove the spare from behind the rear axle and stash it in the trailer if I were going overboard.
My question is, do I really need WD? I have a hitch weight scale so I can easily set the tongue at 12% (actually I think it is 13% right now). What does WD buy me? I know the e2 has a form of integrated sway control, but with the 6" longer stinger it also induces more sway in the first place. I'm also looking at that Tuson electronic sway control (if it ever comes available) so with that I wonder if the WC hitch is good enough.
I have looked around on the internet and found these statements:
1) Use WD hitch for any trailer over 2300 lb (ebay hitch FAQ).
2) WD is needed when GTW (say 4000) is over 50% of GVWR (about 6000) (etrailer.com)
3) WC... for hitch weights typically under 300 lbs (curtis trailers)
4) If your trailer weights more than 3500 lbs, you should invest in a WD hitch (curtis trailers)
I note that all the above are in the business of selling expensive WD hitches. My Dodge Ram towing capacity chart says this:
5) A weight distributing system is recommended for trailers over 5000 lbs. (my particular truck actually has a max trailer weight of 4650 lbs).
If you've read this far, what do you think?
  • Does the trailer follow behind you without sway or weave? Does it feel like the tail wagging the dog? What is the percentage of the trailer weight on the hitch? Everything that I've read over the years suggests that the weight on the trailer hitch should be "about" 12%. Then ask yourself is the added stability and safety worth my family's safety? You're the only one that can answer that last question.
  • Hitch is probably rated at 500 lbs without WD system
    How would I know what to look for? According to the owner's manual the 1500 has either a class 3 bumper hitch (I don't have that) or a class 4 hitch (I think that is what I have - it takes a 2" stinger). I guess that takes a lot more than 500 lb. The reason for the low trailer weight on this one is solely due to the 3.21 rear axle. Other axle and engine combinations pull a much higher weight.
    I have calculated the various axle weights and so forth and I'm within the limits using the WC hitch. I will confirm this at a truck scale shortly.
  • Most of those "rules" are hogwash since they're based on trailer size. Such advisories might hold true for sway controllers, but that's a whole different subject from weight distribution systems, many of which don't even perform that function.
    Necessity for W/D is based strictly on the capacity of the tow vehicle to handle tongue weight. From your description it sounds to me like you've got plenty of payload, and that the rig will ride just about perfect once you're sittin' in the driver's seat. Give it a try without and see how things work. If you're concerned about sway potential, friction sway bars are an easy add on without all the hoo-haw of a w/d hitch.
  • Paulx wrote:
    I have an 18' TT with a tongue weight of 500 lbs,
    You likely just answered your question right there. Hitch is probably rated at 500 lbs without WD system, so you are maxed out by just hooking up not counting stresses on the hitch from moving down the road. Use the WD Hitch system, you already have it, only take a minute to install, and increases you safety plus puts some of the tongue weight back on the front axle.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 09, 2025
