Kansas_couple's avatar
Jun 16, 2015
Use WD setup with 3/4 ton?
I bought my TT about a year and a half ago. TV at that time was a half-ton Suburban. I knew before the purchase I needed a WD hitch, dealer set me up with an EZ-Lift.
However the Suburban has since had several problems and I finally bit the bullet at the end of January and bought a 2014 Ram 2500 gasser. I've looked at some other folks' setups and noticed some 3/4 ton trucks didn't have WD in use.
My TT is a 23-footer with a dry weight of 4100 lbs. Any thoughts as to whether I should stay with the WD setup and possibly adjust the chains for the newer TV, or just have the weight on the ball?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
