Walaby's avatar
Walaby
Explorer II
Jan 19, 2016
Using a 2.5" to 2" reducer with WD Hitch
So the new TV I just bought has a Class V hitch (2.5" receiver), and my WD hitch is for Class IV (2"). I decided to buy a reducer for $12 from Amazon. Part came in today and it says Warning: Do not use with WD equipment". Guess I really didn't think there would be an issue, as long as I don't try to exceed the ratings for a Class IV hitch (which I am way under anyways).
So, I guess a question to the group. Is anyone using a reducer to accommodate a Class IV hitch used with a Class V receiver? Is it safe/okay to use as long as I don't exceed the Class IV weight ratings?
I suppose I can go to my dealer and get a Class V hitch for my setup. Haven't checked that option to see if they have one in stock.
Mike
  • Your Ram should have come with a reducer from the factory. Mine was located in the little storage compartment in the rear footwell. Maybe it's still there?
    Curious as to why the reducer would have that restriction on it. What could possibly happen?
  • If the warming on the reducer says, "don't"....I wouldn't.
    There's the BEST advise about the reducer you purchased.
    I have seen other manufacturers' 2.5" to 2" reducers with no warning such as that which I would feel much safer to use.
  • I don't see why it would be unsafe at all, but it may be clunky. Some on here have complained that the reducer sleeves are a little sloppy feeling (not an issues I've noticed with my stock reducer, which doesn't have any warnings on it).
    You may as well give it a try since you have it. If it works, great. If it doesn't, buy a new WD hitch and sell the old one on Craigslist.
  • It might be JUST the reducer you purchased. My Chevy (in my signature below) came with the reducer when I purchased the truck. I've been towing my TT (with the 2 inch shank with an Equal-i-zer) with no issues at all.
    If the warming on the reducer says, "don't".... I wouldn't. You've got too much at stake your pulling behind you. Go to your Ram dealership and get the right one you need that's really made for your truck.
