rockhillmanor
Oct 30, 2017Explorer II
I winterize by adding anti-freeze to the fresh water tank. And pump thru lines this IMHO, JMHO insures me that the antifreeze gets completely into my water pump. The one year I did not do it this way the following spring I had to replace the water pump. :(
That all said. This is what I finally found to get antifreeze in a pesky placed water inlet.
It bends in all ways will add water even in a 45 degree angle! AND expands and contracts to just about any length configuration you need. Then held upright and pour away.
Couple of bucks at walmart in automotive department.
Looking for advice before your next adventure? Look no further.25,201 PostsLatest Activity: May 28, 2026
