Brownleaf's avatar
Brownleaf
valve stem extenders
I have a 2004 24' minnie winnie. I have read alot and viewed alot on youtube about extenders. I have rubber valve stems now. Several people have complained about places that will replace the original short rubber stems with the long metal ones. Can someone give me a specific reference to a brand and place to buy an extension that would not be too heavy for my present rubber valve stems. Thanks Doug
  • Grit dog wrote:
    StirCrazy wrote:
    Why they would complain about getting better quality metal valve stems is beyond me. the rubber ones are not made for the higher pressures.
    Another wives tale.
    I mean rubber valve stems may not be big pressure. And are common in lower pressure apps. But whether a valve stem has a metal barrel or not is not necessarily indicative of its rating.
    not really a wife's tale its right in the product literature. the standard rubber is rated for applications up to 60 PSI, I am sure they will be fine at 80 as there has to be a safety factor built in but there is pretty much no extra work/cost for them to install a metal one
