TOMMY47's avatar
TOMMY47
VERY slow air mattress leak
I have a VERY slow air mattress leak. Barely there but, after a few hours sleeping on it,it loses 1/2 the air. If just filled and left alone, it takes a day and a half to lose half the air and never loses much more.
Did the soapy water routine with no visible leak.
Any ideas where it could be or is it a lost cause?
  • Have someone sit on the mattress while your spraying with soapy water - might help.
  • I did overfill it a lot.
    Did it around the valve too. I thought that's where it might be.
  • Over inflate the mattress, then do the soap/water test.
  • You soaped up the air valve?
    If the air leak is VERY slow, you won't see much bubbling unless you squeeze the mattress.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
