93Cobra2771
Aug 22, 2013Explorer
Need-A-Vacation wrote:
My question is IF I buy a set of air bags, then set my hitch up while the bed is empty with the minumum psi in the bags, then load the firewood up, and use the bags to return the rear to the same height as the "no firewood" truck/trailer combo was, will this possibly unload the bars?
I am hoping that if not, I can lower the bags to the minimum psi for the return trip home with an empty bed, not having the wd bars be off at all.
TY!
Chris
As long as you return the rear to the same height as before, you will have no problems. As an added bonus, you will enjoy the added stiffness in the rear the bags will give you.
Airbags are wonderful in that respect, as they allow infinite adjustability when bed weights are changing.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 18, 2026
