hikerboy1's avatar
hikerboy1
Walmart Tire & Lube Express - Carlisle Radial Trail HD
I see Walmart has my size of Carlisle Radial Trail HD on sale for a great price - - there is a Walmart Tire & Lube Express about 20 miles from my house, but reviews seem to be inconsistent at best....some 5 star, others 1 star. My local tire shops (Les Schwab and Point S) carry Towmax and Transporter, respectively) but I could save about $200 on the Walmart/Carlisle option....probably a better tire than either Towmax or Transporter. My trailer uses ST205/75R15 C tires. Anyone with points to consider using Walmart as a tire installer? It appears the biggest complaints about WM is the longer wait for installation.
Thanks!
  • hikerboy1 wrote:
    downtheroad wrote:
    I'd go with Goodyear Endurance in the same size except move up to load range D. Les Schwab and Discount Tire can order them for you.
    I considered those as well. My rims are stamped "max load 1820 lbs", which is the max load for my load range C tires at 50psi. I'm wondering if it would be OK to go to a D with a 65 psi rating on the wheels?
    I wonder if the wheels are stamped with a maximum air pressure? It may well be that your wheels are the limiting factor and upgrading to a greater load capacity tire will be negated by the wheels.
    Regarding the 1 star rating for the tires your are considering remember most RV tire failures are caused by overloading, under pressure, over speed, or over age.
  • I'd go with Goodyear Endurance in the same size except move up to load range D. Les Schwab and Discount Tire can order them for you.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
