amandasgramma's avatar
Aug 05, 2014
Warning -- wind damage.....awnings!
I've been doing a little research about electric awnings. I ran across an RVNet thread from last year discussing electric vs manual. One person said he ties down his awning, has the de-flappers, and uses buckets to hold down the awning. Attached is the result of a gust of wind that ruined our friend's awning. The awning was being held down by TWO FORTY pound cement BLOCKS. You ask if the straps broke.....noooooo. He found one of the blocks on the back side of his rig. The wind took the awning up and over and the 40# block went with it........he found the block in the field behind his rig. Thankfully, his rig wasn't damaged and there was no one camped behind him!!!!!! So, if you think those buckets full of rocks will hold down an awning in a big gust of wind.....think again. :)
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
