tenbear
Jul 14, 2014Explorer
I replaced my black water valve some time ago when it was damaged. If you can get the pipes on either side to move about 1/2 inch apart It is an easy job to replace the valve.
I hope your black tank isn't full. Mine has 2 valves, one at the tank, the other in the usual place. Fortunately, the lower one broke.
If you place a bucket under the valve you should be able to catch most of the contents of the tank if you are careful. Good luck!
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
