Berkey filters.  It is a counter top filter.  Use it for ingesting.  Use it at home and for traveling.
Distilled is fine if you are making drink mix, but plain distilled water is not for drinking as it will leach out minerals and salts from your body's cells.  This does not mean death, but it is not ideal to stress your body this way.  Your body pulls what it needs out of your cells to mix into the incoming water to bring your pH and minerals back to balance.  Tap water is more neutral, even with all its toxins.
Bottled water can be as toxic as tap water in some instances.  You are better off using a quality filter if you care about your water.  But most of you drink tap so this is of no concern.
