mrkoje's avatar
mrkoje
Water heater bypass not working?
So I'm winterizing my trailer today and at first I don't know where the darn water heater bypass valve is. I finally locate it under an access panel which is under the mattress to the front queen bed. I proceed to turn the valve off so NO cold water should be hitting the water heater.
Now I go and turn the fresh water bypass valve on so it stops pumping from the fresh tank and now from my bottle of antifreeze.
Ok so I'm ready to pump antifreeze through the system - I place the hose into the bottle of antifreeze and turn the water pump on and WHOOSH the whole bottle is almost instantly sucked dry. I figured I would leave all of the faucets closed until the system had some pressure. Now I open the cold and hot water faucets rotating through the coach but I am only able to get a little (maybe half of the bottle of antifreeze) to come through the faucets. Where did the rest of this go? I proceed to use another bottle of antifreeze and again I notice that I am not getting as much out of the faucets as I should be.
So.. I go outside and take the plug out of the water heater tank and SPLASH - PINK******EVERYWHERE.
My question is going on if I have the bypass valve turned on that is supposedly cutting off all water to the hot water tank? Why am I getting the pink stuff in the hot water heater?
The only logical explanation that I can come up with is that the valve cutoff to the water heater tank is maybe not turned on all the way? I doubt this though because I really yanked on that sucker. Maybe I should double check this?
Another concern is maybe with out the hot water heater is plumbed. Cold water goes in the bottom and hot water comes out the top. The bypass cuts off the water supply before going into the bottom of the water heater tank but it SEEMS to route it up to the top and out through the hot water lines. Is it possible that when I turned on the hot water faucet it started sucking some of the antifreeze into the water heater tank and also some of the antifreeze through the hot water lines to the rest of the faucets? Should I have not turned on my hot water faucets while doing the antifreeze deal?
I do not remember having this issue at all on the last trailer that I owned.
Any answers would be greatly appreciated.
  • I'm confused by your first statement........
    So I'm winterizing my trailer today and at first I don't know where the darn water heater bypass valveis. I finally locate it under an access panel which is under the mattress to the front queen bed. I proceed to turn the valve off so NO cold water should be hitting the water heater.
    Turning the valve OFF would be closing it. So what valve did you close?
    Do you have a 1 valve system on WH
    Valve parallel..cold water goes into WH. Valve turned 90 degrees...cold water bypasses WH and 'check valve in HOT outet stops flow into WH
    Do you have a 2 valve system on WH
    Both valves have to be turned 90 degrees to bypass WH.
    Sounds like the anti-freeze flowed backwards into WH thru HOT outlet.
    Either bad check valve OR you have another valve that needs to be operated
  • Had the same thing happen to me, after draining the HWT the check valve on the hot water tank outlet was stuck open. It's only about 3/4 of an inch long in reality, and easy to miss. You should drain the HWT, shut off the input valve to the HWT, open the bypass and then will all taps shut maintain pressure BEFORE you let the pressure off and then introduce the pink.
    If the check valve is stuck open pink will fill the HWT and splash out on the ground with the drain plug open. It takes a lot of flushing to get that nasty bugger out of the HWT tank... then change the faulty valve, then do it right.
  • yes if the bypass is working antifreeze shouldn’t enter the WH, even if all the faucets are open…
    what you don’t know is if the check valve or the flow diverter valve is bad… my money is on the check valve but I have seen the flow diverter valve leak through to…
    you could replace it with a regular valve if you want… a second advantage is you may get better flow and pressure from the spigot… for that matter you could replace both with regular valves and add a third one in the bypass tube…
  • Vulcaneer wrote:
    jsr21 wrote:
    If you only have one valve to bypass your water heater then it is
    the system that uses a check valve in the top fitting in the water tank to prevent afreeze from entering the water tank. I had to change one today....sounds like yours needs changing to.
    This gets my vote. Remove the check valve from the top (inlet) fitting. If you can blow air thru both ends, it needs cleaning or replacing. They like to attract calcium deposits...and that keeps them from closing completely.
    This could be a possibility but the trailer was built in April 2013. Could deposits accumulate that quickly? I've taken maybe 11 trips in the rig so far. If so then I need to find a better solution so I don't have to replace the check valve every year.
  • If you only have one valve to bypass your water heater then it is
  • We had the same thing happen to us today as we tried to winterize our 2011 Bounder motor home. Never had a problem before but the bypass did not work! Almost all the antifreeze went to the hot water heater. We did get enough in the lines that "pink" flowed through everything except the washer, but it took 9 gallons of antifreeze! We normally use about 5 gallons which i think is a lot. I am very interested in others opinions as to what may be the problem.
  • If you have both faucets open at the same time the liquid will travel from the cold side backwards through the hot faucet until it pressurizes the whole hot water side.
    Only open one faucet at a time when pumping AF through the system.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
