ktmrfs
Mar 29, 2017Explorer III
first, if you have a switch for the AC element inside the trailer check and make sure the switch outside in the wh is also set to ON. most of the time they are set off and you need to change it. then the inside switch will turn on the element. the inside switch is a 12V signal to a relay inside the wh control board.
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Feb 21, 2026
