MFL
Mar 30, 2017Nomad II
Like usual, Old-Biscuit covered the workings very well. He also mentioned, if turned on, no water in tank, element will burn out. I always make sure to check/push outside switch to off, before draining heater. It's just too easy to forget! If you plug the trailer in, switch on, the element is toast, if tank is empty.
Jerry
Jerry
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Feb 21, 2026
