BB_TX
Mar 30, 2017Nomad
Various problems found by others when WH not working on electric include:
- bad heating element
- bad thermostat
- bad hi temp cutout switch
- bad on/off switch
- loose neutral wire connection in junction box on back of WH
- bad/loose wire connections else where in circuit
- tripped breaker
With a voltmeter and the schematic shown above you should be able to isolate the problem if you are comfortable troubleshooting 120 vac electric.
- bad thermostat
- bad on/off switch
- tripped breaker
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Feb 21, 2026
