wnjj
Mar 30, 2017Explorer II
acritzer wrote:BB_TX wrote:
Various problems found by others when WH not working on electric include:
- bad heating element
- bad thermostat
- bad hi temp cutout switch
- bad on/off switch
- loose neutral wire connection in junction box on back of WH
- bad/loose wire connections else where in circuit
- tripped breaker
With a voltmeter and the schematic shown above you should be able to isolate the problem if you are comfortable troubleshooting 120 vac electric.
I'm not particularly comfortable trouble shooting electrical systems and don't eeven have a voltmeter. So, for $15 and what I think is the most likely problem I plan to replace the element today. Hopefully that's the issue.
The most likely is the switch is off. I assume you checked that?
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Feb 21, 2026
