PapPappy
Jul 08, 2013Explorer
Bad check valve, or is there a valve in the bypass system that is in the wrong position? It can get confusing?
Are you getting pressurized water coming out the pressure vent valve on the outside of the water heater? This would indicate that you are getting pressure into the tank, and that the "out" line is plugged or a valve is shut.
When testing, make sure the water heater isn't on, to avoid getting burned.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
