jesseannie's avatar
jesseannie
Water in pilot light tube on water heater.
I have been having a problem with the pilot light on my manual light Atwood water heater. When it is raining the pilot light won't light.
Today I took off the gas line to the pilot tube and blew into the tube and a little spritz of moisture came out of the pilot tube. And it rained last night.
After doing that a couple of times I put it back together. I used the butane ignitor and held in on the tube for a minute or so to get it dry inside and it lit right up.
I cant see that there is any way that rain is dripping into that tube inside the water heater enclosure.
Is it possible that the rain coupled with temperature change is causing condensation to form in the tube? Is it coming from the propane tanks?
If so why? And what do I do to deal with it?
I don't want to take the heater apart everything I have to light it.
This has been going on for a year off and on, I have a new regulator and pilot tube assembly, which did not solve the problem. It just lightened my wallet by 400 bucks.
Two RV techs have looked at it and don't have a solution.
Jesseannie
  • Moisture (oily residue) is the result of 'carry over' from additive in propane ---ethyl mercaptan
    It is added in small quantities but can build up especially in the smaller pilot tubing on any pilot flame appliances
    Did you ever check if 'real' problem is the thermocouple shorting out as posted in your other rain issue thread back in July 2016 that you never responded to?
