The typical exterior inline pre-set regulators are rated for around 2 gpm or so. I installed a Watts 263A regulator inside which are good for 4-4.5 gpm. RVwaterfilterstore.com has a Fairview inline exterior regulator that is rated 10 gpm and 60 psi but is $35. I have our Watts regulator set at 60 psi as recommended by RVwaterfilterstore.com. RV water piping systems are supposed to be good for at least 100 psi.
The typical exterior inline regulators have a small orifice inside and a small regulator mechanism and can plug up with silt & debris quickly. The first inline regulator we had only lasted a year and have read of others having the same happen. They are not designed to be rebuilt, unlike a Watts regulator (or similar).
"Quality" regulators like a Watts publish flow vs pressure graphs like
here for example but you won't find such a graph or specs for the exterior inline types so performance will be unknown.
I once tested an inline regulator at home by varying the input pressure from our well. It didn't regulate very well across varying input pressures up to about 100 psi. I didn't keep my notes but would be an interesting experiment for someone to try.
One thing about the exterior regulators to note is that they are best used at the faucet end of your hose and not the at the city water inlet so that the hose is protected against high pressure. However, it's possible to forget to remove it from the faucet. Some CGs can have pressures well in excess of 100 psi which can potentially blow a hose. I use a Valterra high pressure rated hose because our regulator is inside.
A gauge after the regulator is a good idea and also one ahead of it. The highest pressure we've encountered so far has been 120 psi.
If you are going to use a filter(s), they should be after a regulator because some filters will be damaged by high pressure.
