YES......even a new rig the water pump check valve can leak back to fresh water tank.
The internal pump check valve (just a flapper assembly) can get debris stuck in it that doesn't allow it to close.
Debris is usually from construction/installation.
Put some water in tank and run pump thru a faucet with aerator removed and flush it out.
IF it still is back flowing you may need to disassemble pump head and clean flappers.
Doubt if it is damaged..just stuff stuck in it.
OR just add an in-line check valve to pump discharge line.
Looks like that Viewfinder has a standard gravity fill on side of rig for fresh water tank.....so no 'mis-valving' just debris stuck in pump check valve from installation of tank.
Flush tank thru drain and then run pump to clear debris from inside pump.
Enjoy.....nice looking rig.
