acritzer's avatar
acritzer
Explorer II
May 31, 2017
Water pump not pumping.
Worked ok the las time out. In between it was in for a fresh water tank leak. Now it's not working. Seems to turn on, but doesn't generate any pressure or pull water up. No closed valves that I can find. When I pull off the filter side it seems be generate suction.
Not sure what to do. Anyway to try and "prime" it?
  • Try "charging" the water system using the city water connection. D/C city water, turn on pump...
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
