esox07's avatar
esox07
Water pump runs when not using water
My water pump kicks on and off every 4 or 5 minutes, even when we are not using any water. Is this normal for the system to slowly lose pressure or should I be looking for a leak somewhere? I have looked for leaks, but cannot find any. Either inside or outside the camper.
KZ-Sportsmen 19BH trailer for reference.
Thanks.
  • I had this problem and replaced the check valve to cure it. It was a cheap part and a quick repair. The most time was spent removing and reinstalling the pump.
  • OK, thanks. I didn't think of the pump itself allowing backflow to the tank. That makes sense. I will try running a full tank of water to see if that helps. It does seem that at times the pump doesn't cycle or very rarely cycles without water being used...so maybe the "check valve" is allowing some backflow at times due to debris being trapped.
  • It's leaking somewhere or the pump is leaking internally back to the tank. It only takes a very slow drip. My sons FW was leaking very slightly at the low point drains and the pressure side of the pump dump valve. I replaced the o rings in all three valves and problem solved. I have run his pump then shut it off and turned it on a week later and it didn't cycle.
  • It could be an internal leak in the pump. It is sometimes caused by debris being trapped in the pressure valve. It sometimes can be cleared out by running a whole tank of water thru pump with faucets open. We are having the same problem with ours and our mobile rv tech guy gave us this explanation because we couldn't find any leaks either. Good luck!
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
