ugeesta
Apr 19, 2014Explorer
Water Pump Sucking Air
My water pump is sucking air and I think Iknow the problem area.
Last year I installed a winterize valve and had trouble connecting the water hose to the extended end of the water pimp intake. Like a good man, I pulled on the hose and forced fit the connection. Now e pump is sucking air :S
After filling the water tank to the overfill point, I start the pump and it still gets air.
If I apply pressure to the water intake and filter, the pump starts to operate normally and stops when the pressure is right.
I don't believe there is a crack in the plastics but I think the two piece elbow is stretched out causing e air leak. Can I Jerry rig this elbow or is it better to just get a new one? If a new one is in order,does Walmart carry them?
Thanks.
Thanks.
