mojoroo
Jun 02, 2013Explorer
OK I will need to read your post a few times, I am a bit slow with math along with new terminology. Ron you are very well versed and helpful in regards to WD discussion, thank you!!
Yes the weight of the TV was from the day before and I am sure I burned 6-7 gallons of gas inbetween the truck only weight and the TV+TT combo weights, I also had case of soda removed.
I will try to digest the numbers a bit more.
Until then it appears I should try to transfer more weight to the front via WD?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
