lawrosa's avatar
lawrosa
WD dilemma. Cat scale weights.
I wanted to get better actual weights again with the silverado 1500. I have been running on the 9th chain but I recently installed the sumo springs.
Sing I have really no sag anymore I was concerned.
I did all these at the scales today.
Truck
Truck trailer WD en-gauged
Truck trailer wd dis en-gauged
Me 200 lbs in the truck
Shows a 740 lb TW @ 14%
This is 9th chain
Front axle stock ride. 3300 lbs
WD front axle 3160 lbs.
Almost restored front. I have 8 washers and thats the max I can go I assume.
http://towingplanner.com/ActualWeights/TravelTrailerCatScales/?w1sa=3160&w1da=3100&w1ta=4680&w2sa=3020&w2da=3320&w2ta=4560&w3sa=3300&w3da=2300&a=2
This is what the bars look like 9th chain
OK so on my way out I said lets do chain 8th links and see what happens.
Well bars aiming up, but I restored the front to exactly 3300 lbs
So I moved 140lbs more to the front
And 20 lbs to the trailer.
I still have 14% TW @ 740 lbs?? Strange?
This link
http://towingplanner.com/ActualWeights/TravelTrailerCatScales/?w1sa=3300&w1da=2880&w1ta=4680&w2sa=3020&w2da=3320&w2ta=4560&w3sa=3300&w3da=2300&a=2
and heres the bars.
What would you do?
Also note: The back of bed was empty. I will be having a gen in there, some crates, and a solar panal at times. Maybe 200lbs
And max 3 other people . mabey 400 lbs
Also note my RAWR is 3750
With 8th link this gives me 870 lbs left to add to rear axle
FAWR 3925
on 8th link this gives me 625lbs left to add to front axle
  • This is why I put the sumo's on. had this sag going to Florida.
    But had I known I could do the 8th link I would of ran to florida with it on 8th link
    This is fully loaded camper, 4 people, camper loaded.
  • What can I do with the hitch/WD to get the bars straight and transfer more weight like I did with the 8th link?
    Thinking about it there is probably nothing I can do but get bigger bars maybe?
    These are 1000lbs bars now.
    But tilting head back more I think would help, but I have 8 washers already.
    maybe remove the sumo springs?
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
