Baja_Man's avatar
Baja_Man
WD Hitch - Selection Questions based on TW and GVWR
UPDATE:
Purchased toyhauler today (2009 Tahoe 284SA)!!!!
Weighed TW today...
TW dry (water/waste tanks empty, nothing stored inside or outside ot trailer....
First weigh: 1400#
Second weigh: 1500#
Average: 1450#
So, based on the 1450# TW.....what hitch is recommended?
Keep close to the 1450# TW....(ex. Equal-i-zer) or go with a higher weight rating?
Examples.....
Equal-i-zer 1400# (had two before and both worked great!)
Blue Ox.....1500# or 2000# (never had chains....reliable and sway control?)
Reese?????
Thanks!
Getting ready to pick up a new to me toyhauler. Need to purchase a new Weight distribution/anti-sway hitch set up.
TH specs:
GVWR: 13000#
TW: 1300#
UVW: 7950#
If the TW is listed at 1300# (per specs), it is using a 10% formula. I don't know for sure if this is the actual weight without taking it to a scale. Since I do not have a hitch to take it to a scale, this is not possible.
On my last TT it had a TW of 1200#. I purchased a 1400# Equal-I-Zer hitch and it worked great!
Questions:
If TW is between 800#-1700# (unloaded to fully loaded-10-13%), is it wise to get a WD hitch system on the high weight end of 1700#? I am concerned that if TW is much less than this (ex. unloaded) there could be a problem.....what could the problem be? Ex...too much hitch rating vs too little hitch rating.
Also, should ball height on truck (for shank selection) be measured at trailer ball coupler height at rest....OR....after TW has been applied to truck ball?
Ex. If Trailer coupler ball height is 21" at rest, should my truck's ball height ball height be the same 21"? If so, once TW is applied, truck rear axle will drop once weight is applied and trailer will no longer be level.
Thanks!
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
