Ron_Gratz
Mar 05, 2015Explorer
DwnSth wrote:It doesn't make sense to me.
---It does make sense that some of that weight has to be handled by the WD system.
IMO, since you don't handle that weight when you're not towing -- you don't need to handle it when you are towing.
---Only question I had left was, is that rear weight considered in the receiver limit? If so, I don't want to put anything rear of axle so as not to go over receiver limit of 1130.There is no way for weight in the bed of the truck to impose a load on the receiver.
It doesn't impose a load on the receiver when a trailer is not attached,
and it doesn't impose a load on the receiver when a trailer is attached.
If you choose to transfer extra load to the TV's front axle to compensate for behind-axle-load, you also will transfer extra load to the TT's axle and decrease the vertical load on the receiver.
Ron
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
