Ron_Gratz
Mar 06, 2015Explorer
JBarca wrote:John, there is no weight (mass) added to the A-frame. However, the tension rise in the WD bar does cause an increase in the downward force exerted against the A-frame by the WDH chains.Ron Gratz wrote:I agree with you "if" there was weight added to the trailer A frame. That was not what I was saying or thinking. There is no weight change on the A frame.---JBarca wrote:If the downward force exerted on the A-frame by the WD bars is increased, the load on the TT's axles will increase.
OTOH If after you had adjusted the hitch as described above;
And you add extra weight to the truck bed behind the truck rear axle which is a large enough weight and or far enough behind the axle to lower the back of the truck, this can change the hitch head angle relationship to where it was originally adjusted to and add a level of tension to the WD bars. How much tension rise in the WD bar depends on how much the hitch head angle changed.
Since the weight of the trailer has not changed, and since the trailer axles now are carrying more load, the vertical load on the receiver must decrease by an amount equal to the load increase on the trailer axles.
I was trying to point out that weight behind the TV's rear axle does not increase the downward force on the receiver.
My thought was;I agree 100%.
- The back of the truck was lowered by adding enough weight to truck bed (and the farthest back from center of the rear axle increases the moment)
- The added weight will compress the truck suspension to change the hitch head angle.
- The hitch head angle will tilt back the head (not a lot, but still be towards the TT)
- This head angle change will increase the WD bar tension for that point in time the weight was added
- The back of the truck will rise to create equilibrium once again but at a different lower vertical location.
- If the WD bar is sized larger, the drop effect will be less.
IMO, if the added drop due to behind-the-axle weight is unacceptable, it is better to compensate for that added drop by using a rear suspension aid.
The problem with using the WDH to compensate for rear end drop due to bed load is that doing so will contribute to undesirable oversteer.
When load is added behind the TV's rear axle, load on the rear axle will increase and load on the front axle will decrease. This, by itself, will increase the tendency to understeer.
However, the behind-the-axle weight also causes the TV's center of gravity to move rearward. That makes the front tires more effective at steering and the rear tires are less effective. This, by itself, will increase the tendency to oversteer.
The two effects -- 1) changing the axle load distribution and 2) moving the CG -- tend to cancel each other.
If you then use the WDH to compensate for the effects of bed load, you are decreasing the rear axle load and are increasing the front axle load. This increases the tendency toward oversteer -- which is not a good thing when towing.
In the past few years, TV and WDH manufacturers have been specifying reductions in WDH load transfer based on directional stability considerations.
IMO, using more highly rated WD bars to achieve more load transfer is in direct conflict with the recent changes in Front Axle Load Restoration specifications.
It took some time for the WDH industry to make the FALR changes and, I guess, it'll take some more time for them to change their minds about using the WDH to compensate for bed load.
Ron
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 27, 2026
