TommyC83's avatar
TommyC83
W/D on 3/4 ton
Just curious if anyone uses or recommends w/d hitch for a 3/4 ton. My tonhgue weights is just around 900lbs give or take (havent weighed fully loaded just yet) Im coming from a tundra and used w/d on my previous trailer and loved it. I got a bigger trailer so stepped up to a 2500hd. I need to order hitch parts either way I just dont want to spend the money on a standard hitch setup if im going to want w/d after the first tow. But also dont want to spend $500 if its not needed. Truck has classv reciever rated for 1500lb tongue weight.
appreciate any input
  • Yes, I recommend you purchase and use a WD hitch with that truck and that trailer.
    Barney
  • I would say yes to the WDH. Better yet, something with built in sway control.
  • I'm towing about that much tongue weight without a WDH, but I'm towing with a DRW F350 and air bags. If I had less truck I'd probably go with the WDH.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
