handye9's avatar
handye9
Explorer II
Apr 20, 2015
WDH with air suspension, no standard answer?
We're seeing more and more questions regarding weight distribution hitches being used with air suspension equipment. If you do a google search on the subject, you'll find some vehicle manufacturers, tell folks to disable the air ride, adjust WDH, and turn the air system back on. Then there are some, 2015 GMC Yukon is one of these, that tell folks to let air ride adjust itself, then install the bars.
2014 Ford Expedition (owners manual), actually says "hitch up without WD bars, drive 20 - 25 MPH for 2 miles, then install and adjust the bars". I wonder how many folks are doing this?
Here is an air equipment company, telling folks to disable the air suspension, while adjusting WDH. Link
Many WDH manufacturers (as do many vehicle manufacturers), discuss using fender well measurements as an indicator of front axle weight restoration. I would think, if the air suspension has already leveled the vehicle, wouldn't fender well measurements be useless?
Other than scale weights, how would one know if you had propper tension on the bars?
Kind of difficult to answer peoples questions about using the two systems together.
Anybody else noticed the confusion?
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 01, 2026
