I have a 2020 No Boundaries travel trailer with a Lippert torsion axle w/ 15" wheels. The brakes are pretty weak even with the camper empty. I've towed numerous campers so I understand how the brak...
Put your DC clamp-on ammeter on the wire to the brake while your buddy manually applies the brake controller. You should see about 3 amps at each wheel. Too high is a short, too low is a bad connection.
And yes by all means adjust the brakes and eventually remove the drums for inspection. Does the trailer have those grease fittings on each hub?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
