yeabuddy's avatar
yeabuddy
Weather Radio
I purchased a pair of these to keep in touch when around the campground. It has weather alert capabilities but was wondering if it's enough?
Is this sufficient or should I buy something more specific?
What weather radio do you recommend?
  • I have a old Realistic Crystal controlled desktop that has a extendable antenna and folds up to shirt pocket size. Press the button and it throws you the NOAA broadcast for that area.
    Looks for something similar and I don't see anything at radio shack (where I bought mine). Works wonderfully everywhere I have ever taken it. Battery lasts forever.
    Make sure whatever you get, it has an extendable antenna. A couple of friends have one with "built in" antenna's and they are hit or miss on getting anything when the weather gets bad and they need to know.
  • They will work fine if they pick up one of the weather channels.
    Provided it is turned on. At home I use the plug in Midland weather
    alert radio. It is always turned on in standby and works great.
    Brian
  • http://www.walmart.com/ip/Midland-WR120B-Weather-Alert-Radio/16451519
    We bought ours at Walmart. You can either program the exact county where you are, or leave it on "all" counties which we do. That way we get alerts earlier and can tell which way the storm is coming and how fast. We've used it all over the US. Only $38. We leave it plugged in all the time. It has battery backup. I think 2 would be safer. We have ours in the bedroom so it will awaken us.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
