Does adjusting the wdh a little bit downwards (towards the trailer) allows fir better weight distribution? Mod Edit: Removed the big pic. See below for normal size pics
I'd suggest going to the towing forum where there is some excellent info. on setting up a WDH. THs have their own challenges due to the large swing in TW that can happen from loaded to unloaded.
Note that receivers have a max. hitch load rating when spring bars are not hooked up (typically 500 lbs). Not a good idea to tow without the bars in place for that reason PLUS you need to get the correct amount of weight back onto the steer axle.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
