cs2kplus's avatar
cs2kplus
Weight Distribution Backing Up
I have seen on the internet somewhere saying to REMOVE weight distribution when backing RV in. Is this true?
  • I was backing into my steep driveway. I am thinking I may just remove the bars in that case only. Otherwise I hear all the hmmm and hawww of the linkages.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    bob213 wrote:
    I never remove mine while backing. (Equalizer)
    X2, and I never removed the bars with my old EZ Lift either.
  • If your type of WDH has a built-in anti-sway function, disable that to make backup turns easier. Release the sway bar, drop the chains or un-mount the bars whatever. I found that to work best for me.
  • Most hitches are only rated at say 7,500 pounds while not using a WD system. I know that rating is for towing down the freeway at 55 MPH, and your backing will only be done a few feet into a campsite at less than 10 MPH, but still it is a rating!
    Yes many do disconnect their hitch wile backing up, if they will be making really tight turns. . .
    Good luck,
    Fred.
  • I've got 2 friction sway bars and never take them off when backing but you have to be sure they are mounted perfect.
  • I believe the friction type sway should be disconnected. So that in a tight turn you don't bend everything. I use an equalizer, I leave it on.
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 22, 2025
