Rollnhome's avatar
Rollnhome
weight distribution hitch ...I'm confused.
Where to start....I just bought an enclosed car hauler 10,000 lb. I am towing with a 40' MH. Freightliner chassis auto leveling air bag suspension.
Hitch rating 5000 lb with 500 lb tounge weight. 10k lb flat tow TW N/A. Weight distribution 10,000 lb tow weight 1000 lb tongue weight.
It looks like I need weight distribution hitch or do I since the air ride is self leveling or is there stress on the frame I am overlooking? Wouldn't the two systems fight each other? How could I adjust tension if MH keeps leveling automatically? Man flat towing the Jeep is way easier, but my wife wants to take her little sports car. So we compromised and we are taking her car, what else can I say?
  • newman fulltimer wrote:
    You need a bigger hitch
    Agreed!! Also, look at the manufacturer ratings for the coach's towing capacity, it may be below the hitch rating. Any rig will benefit from an equalizing hitch, just because you may have an air ride suspension that will compensate for squat, does not mean weight has not been removed from the steer axle. A Weight Distributing Hitch is designed to transfer weight back to the steer axle, as a benefit, it also helps with rear axle squat.
  • not sure a WDH would work real well on a 40' MH, as the purpose of a WDh is to transfer lost front axle weight back to the front to return steering control. One way to check I guess, is to measure the front bumper to the ground unhooked, then hookup, and measure it again. See IF it rises with the trailer hooked up. I'm thinkin it won't.
    However you may need one to keep from overloading the receiver.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 06, 2026
