Terryallan
Dec 04, 2018Explorer II
missouri dave wrote:
Anyone use a weight distribution hitch with an auto leveling ram? How do the two work together and how do you set up the hitch correctly with auto leveling?
Some where in the manual there should be instructions. Do your best to find them.
I had a Ford with auto leveling, and the instructions in the manual said to go to a level parking lot. Un hook. Let the vehicle level itself. THEN turn OFF the auto leveling Before the vehicle can lower itself. Don't know if yours lowers itself. Mine did for ease of entry. Any way. once you turn it off. Adjust the hitch normally. And once you get it where it needs to be. Turn the auto leveling back on, and you are done. No need to go thru it all again.
Yours may be different. But it is important that the vehicle be up, and the auto leveling be off. IF not. It will level itself while adjusting the hitch, and cold cause the WDH to be adjusted wrong.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
